Keyur Kanade
You need to create geometry as you create for non porous zones.
The porous properties will be applied in Fluent.
Please check following section in help
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/flu_ug/flu_ug_Fluid.html%23flu_ug_Fluid
Keyur
