Keyur Kanade
Please check if you have any sharp angles in geometry. If yes, try to remove sharp angles.
Also please make sure that your inflation controls are correct.
Please select appropriate faces for inflation.
Please search forum for similar questions.
https://studentcommunity.ansys.com/thread/mesh-quality-reduction-after-inflation/
Keyur
