Leave gpu as zero. For meshing leave cpu as 1 (you won't see any speed up given the low cell count you're going to generate). For the solve 2 cpu should speed things up: make sure you're not surfing the internet etc when doing the runs. Threads means you have hyperthreading turned on. We tend to disable this as it's not really worth using for CFD.
