DrAmine
If you are using VOF you will only get a single velocity field and single temperature field. So you just write an ASCII file with all what you require + VOF fraction. Based on that VOF fraction you can then know whether you are in one phase or in the other. If it is between 0 and 1 you are at the interface region.
