Keyur Kanade
Make sure you have a solid body for aircraft object.
Please check geometry in SpaceClaim.
Select geometry in structure tree --> Use right click --> Select Check Geometry.
The geometry should be error free to proceed.
If geometry has any errors, please modify/recreate geometry at those places.
Keyur
