ananyas
Hello Amine,
1. mPa is milli-Pascal.
The issue is I don't see any pressure variation for the inlet (10 mPa) or outlet (0 mPa) in either contour plots or pressure plots w.r.t. time.
2. I am using Pa as the unit and so I use an amplitude of 0.005 to represent 5mPa.
here again, I don't see any sinusoidal behavior when I plot the pressure w.r.t. time.
Best,
Ananya
