Shekhar
In my opinion, firstly you have to select those elements which you want to choose through 'ESEL' command. For that CMSEL command should be issued prior to ESEL. Since the component "part1" is not defined that is why it is showing 0 to 0. Use CMSEL to define part1. Then *GET command to get the maximum and minimum number of elements in the component 'part1' or use *GET to get the maximum and minimum number of nodes in the component 'part1'.
