tsiriaks
Hi Ben,
There is an issue with your 'ansysli_server.exe' process to bind the socket 2325 (which is its default port)
The fact that license status and AEDT licensing works means your lmgrd.exe and ansyslmd.exe, which are pure FlexNet licensing, is working fine.
You can try adding Firewall exceptions/Anti-virus exclusions to the  ansysli_server.exe process.
By the way, does the server machine have multiple NICs ? If so, it may be best to specify hostname of the license server (instead of IP) and just set
ANSYSLI_EXTERNAL_IP=
in C:Program FilesANSYS IncShared FilesLicensingansyslmd.ini
Thanks,
Win
