tsiriaks
Hi Vasilis,
Your script does the request to SLURM first to get the node list and put that to HFSS batchsolve command. This would need the first node on that list to run Ansoft RSM service, and hence you are seeing this error. There was a discussion about this, ref:
https://studentcommunity.ansys.com/thread/could-not-start-the-memory-inquiry-solver-when-trying-to-do-multinode-hfss/?order=all#comment-e062d205-0b5a-4b8b-b9db-abc201448788
and the user brought up the method described in
https://chpc.utah.edu/documentation/software/ansys-edt.php#ub
which dynamically starts ansoft RSM on the fly, then stops once the job is done.
However, as stated in that post, we do have our own customized script to integrate AEDT with SLURM, so you won't have to manually query nodes then start Ansoft RSM accordingly like this. This is the SLURM custom scheduler proxy that Matt mentioned above.
Let us know if you are interested and we will reach out and provide it to you.
Thanks,
Win
