tsiriaks
I've asked around about this and there are some thoughts
1. Chemkin is a java app ... Is Java installed on the computer and in the user's path? You can use the following command
set | findstr -i java
and post the output of it here.
2. Chemkin may be having trouble creating its environment, which could result in .dlls not being located. Please use the following command
"C:Program FilesANSYS Incv201reactionchemkinpro.win64binrun_chemkinpro_env_setup.bat" > C:Tempchemkin_env.txt
and post the content of C:Tempchemkin_env.txt
