Hugo66000
Thank you for your answer, I understand, so here is the code :
#include "udf.h"
DEFINE_ON_DEMAND(on_demand_calc)
   real u;
   real uavg=0.;
   int i;
   int ph_index_gas = 3; /* This is the phase ID that has my gas in Fluent (foud in "phase") */
   cell_t c;
   Thread *mix_th, *subth; /* I believe mix_th is the mixture level thread pointer */
   subth = THREAD_SUB_THREAD(mix_th, ph_index_gas);
   printf("n test1");
   i=0;
   /* Loop over all cells  */
   begin_c_loop(c,mix_th)
  printf("n test2");
  u = C_U(c,mix_th);          /* get cell velocity */
  uavg = uavg+u;
  i = i+1;
   end_c_loop(c,mix_th)
   uavg = uavg/i;
   printf("n uavg = %g   u = %g   i = %gn",uavg,u,i);
The error is a "received signal SIGSEGV"  type.
I am using a multiphase VOF model and the energy equation. The study is in 2D and the solver planar (so the bubble is more of an infinite cylinder).
Best regards,
Hugo
