mettusagar
Hello Amine
In actual I've to solve the following equation, but there is not any direct provision for solving in terms of concentration.
" alt=""> where C = concentration, Source = -kb.C
But species transport module uses the following equation which uses massfraction and density rather than concentration. and the rest terms are same as of above equaiton.
where
So, I converted concentration into massfraction, as I already know the density of mixture and then gave the input values for simulation.
One another option:
Can I use "User Defined Scalar" for directly solving the 1st equation which contains concentration terms ?
As in my problem, the fluid domain is also porous. So, I also have to give porosity to the fluid domain.
If yes, can I give porosity for the flow domain in cell zone conditions for the equation to be solved by  "User Defined Scalar" ?
  • And also do I need to give the velocity which is represented by 'u' in the equation -  in the UDS code or in the boundary conditions ?
  • And also the term 'D'  which represents diffusivity, where can I define it - in the material properties or in the UDS code ?
Thanks and regards
mettusagar
