lyip6
1) The Set | findstr -i java command doesn't return anything.
2) here is the results from run_chemkinpro_env_setup.bat
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>set REACTION_DIR=C:Program FilesANSYS Incv201reaction
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>set CHEMKIN_BIN=C:Program FilesANSYS Incv201reactionchemkinpro.win64bin
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>set CHEMKIN_VERS=20.1
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>call "C:Program FilesANSYS Incv201reactionchemkinpro.win64binrun_chemkinpro_env_setup_part2.bat"
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>set RD_JRE_BIN=C:Program FilesANSYS Incv201reaction..tpopenjre11.0.4bin
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>set relinfo_file=C:Program FilesANSYS Incv201reaction..commonfilesglobalsettingsrelinfo.xml
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>PUSHD C:Program FilesANSYS Incv201reactionchemkinpro.win64bin
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>FOR /F "tokens=*" %a in ('ReadRelinfoExt.BAT') do set extvers_file=%a
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>set extvers_file=C:UsersJOHNUSERAppDataLocalTemprd_89973240_ext.tmp
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>FOR /F "tokens=*" %a in ('ReadRelinfoInt.BAT') do set intvers_file=%a
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>set intvers_file=C:UsersJOHNUSERAppDataLocalTemprd_61847882_int.tmp
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>FOR /F "usebackq delims==" %g IN (`type "C:UsersJOHNUSERAppDataLocalTemprd_61847882_int.tmp"`) DO set CHEMKIN_INT_VERS=%g
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>set CHEMKIN_INT_VERS=201
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>FOR /F "usebackq delims==" %g IN (`type "C:UsersJOHNUSERAppDataLocalTemprd_89973240_ext.tmp"`) DO set CHEMKIN_VERS=%g
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>set CHEMKIN_VERS=2020 R1
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>DEL /Q C:UsersJOHNUSERAppDataLocalTemprd_61847882_int.tmp C:UsersJOHNUSERAppDataLocalTemprd_89973240_ext.tmp
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>POPD
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>set BUILD_DATE_FILE=C:Program FilesANSYS Incv201reactionchemkinpro.win64build_date.txt
C:Program FilesANSYS Incv201reactionchemkinpro.win64bin>set CHEMKIN_TITLE=ANSYS Chemkin-Pro
