tsiriaks
That's because it's off-screen. You can refer to
https://studentcommunity.ansys.com/thread/workbench-not-opening-2020-r1/
Even though that's resolved, it's still good to try the 'move' command that I mentioned in that post again as it could help with other issues that you may have too.
I'm not sure how the AnsConfigSpaceClaim.exe is missing. Can you re-download the installation package from the website ? What's the name of the package (the file name)
Make sure you completely remove your current ANSYS Inc installation folder before you proceed with the re-installation. Also, use 'run as administrator' when running the setup.exe (the installer)
Is AnsConfigSpaceClaim.exe still missing ?
