chiragthakar29
In the above post I have showed the pic of the mesh details. It also contains the mesh quality properties ,please reveiw it. I am new to ansys so I am not aware about the MRF or sliding mesh analysis.
Boundary conditions :-
1) I have defined the surface of the diffuser from which the air will enter as input.
2) The surface of the diffuser from which the air will come out as output.
3) The fan is defined as fan
4) The outer perifery of the diffuser other than the input and output surface as wall.
5) I have taken the input as velocity inlet and output as pressure outlet.
I hope that these are the things that you asked for..thank you for helping me..
