vishwatejakasoju
Thank you rwoolhou.
I dont have the fluid flowing. The fluid is static and the object is free to fall. Is it because of defining the top wall as a free surface by defining pressure outlet with zero pressure and defining the operating pressure as 101325 pa at a reference point on the top wall? Should i lower my free surface and define a VOF model with air above the free surface to get rid of this message? Also if possible can you please suggest what kind of post-processing should i be doing to figure it out?
Thank you.
