Insert a Coordinate system at the location where you want to extract the internal "contact pressure" so that the Z axis is normal to the plane you want to cut through.
Insert a Construction Geometry and insert a Surface.
Insert a Normal Stress result, scope it to the Surface, using the coordinate system in step 1 and ask for the Z axis component of stress.
That is your "contact pressure".
