Aniket
Posting on behalf of wrbulat (Bill). Thanks for your patience!
Hi Jojo,
As an example, I created a hypothetical linear PM material in Engineering Data:
I assigned the PM material and a cylindrical coordinate system to a ring with polarization in the x-direction:
I set a flux parallel condition on the exterior boundary of the spherical enclosure:
and get flux density pointing radially inward:
Incidentally, we suggest that you set the following variable using Tools > Variable manager to use the newer SOLID236 electromagnetic solid instead of the older and now undocumented SOLID117:
I hope this helps you!
Best,
Bill
