m.caragiuli
Ok Peter,
however, can you explain to me why it is not correct to evaluate the pressure at the interface between the two bodies as the ratio between the reaction force in the contact surface and the contact area? Wha is instead the difference between the pressure and the stress as outputs?
Thanks
