MichaelDelle
I got this solution with having the bottom supports as flexible bodies and not rigid bodies
How should I set up the left and right supports though ? I changed their behaviour to flexible and made the bottom side of the cylinder to be fixed supports alongside the faces while the top side is set up as the frictionless contact with the main body. Should I also add a deformation for all the nodes of my sandwich panel for them to deform only in the Z axis ?
