Karthik R
Administrator
1. If the flow is indeed symmetrical, then you should be able to use the symmetry BC. You should be able to continue using the symmetry condition.
2. In this case, the flow is not going to be symmetrical. You will need to model the entire geometry and cannot use a partial domain.
Thanks.
Karthik
