Samir Kadam
Hey @prajput , you can use this behavior when the dimension in the Z direction is very small compared to X and Y dimensions for a body. When you have flat plates with in-plane loading, or thin disks under pressure or centrifugal loading, you can use plane stress behavior.
I hope this helps!!!
