Kalyan Goparaju
If you have HPPC data from test or if you already have identified parameters for a battery Equivalent Circuit Model (ECM), you can use it to create a lumped model for a single battery cell or a module using Battery Wizard Toolkit. You can connect several modules together to build a pack. In addition, you can use the Thermal Model Identification Toolkit to create a thermal reduced order model for a battery pack. More details can be found in the Battery learning room within Ansys Learning Hub.
