Karthik R
Administrator
Quantities in a simulation can be displayed by creating a Calculator.
Calc1png
The calculator can be configured to show many different values. To show a force such as drag, select the appropriate direction and location for the calculator. You can also give the calculator a unique name. In most cases the force would be calculated for all faces on a body, as shown below:
Calc2png
Click Select, then choose the desired items for the calculator. The value of the force will be plotted in a graph. The graph can also be collapsed to display a single value using the triangular button in the top left of the calculator window:
Calc3png
