mcoderon
Thanks for the files. It is working OK for me, in 2020R1. All the cdat files contain all the requested locations and variables except for "rate of soot", but that is not a cloud issue as the same thing happened locally on my laptop. So maybe there was a problem with the download or you ran out of disk space on your cloud account or on your laptop. Some things for you to check.
check the fluent-*.trn transcript file for any errors during the cloud run, particularly when writing the cdat files.
check the size of the downloaded files to see if they are significantly smaller then they should be.
log into the cloud portal and view your dashboard to see how much storage you have used.
