Karthik R
Administrator
If geometry has any errors then boolean operations may fail. Please select bodies in structure tree --> use right click --> select Check Geometry. If geometry has any errors, please modify or recreate geometry at those positions to remove errors and then proceed. Combine tool also may fail if two bodies are just touching each other and having tangential contact. Make sure two bodies has good intersection and then use Combine tool.
