prajput
When using volume extract feature, SpaceClaim does some boolean operations in the background. If geometry has any errors then boolean operations may fail. Please select bodies in structure tree --> use right click --> select Check Geometry. If geometry has any errors, please modify or recreate geometry at those positions to remove errors and then proceed.
