prajput
Yes, once the solution is done, you can select Solution Information from Outline tree. By default it will show Solver Output in Worksheet tab.  You can switch to Geometry tab (at the bottom left corner of graphics window) to see the Weak Springs.
If it is difficult to locate them due to other FE Connectors, you can set Display to Weak Springs under Details of Solution Information/FE Connection  Visibility.
