Keyur Kanade
Yes, you can do it. In a fresh file, first sketch the profile. Then extrude it using Pull command to create a solid. One important step is to change the color of the face you want to use as the profile. Make sure that this color overrides the color of the solid. Then save the design as an SCDOC file.
Now to use this profile as your beam's cross section, click Profiles, select More Profiles, and then browse to locate the SCDOC file.
