Keyur Kanade
Why are you using layering?nIs this 2d or 3d? nIt looks like you have 2d tri mesh. nFor this you need to use remeshing. nIs mesh scale info you are showing is after you encountered negative cell? Can you please give mesh cell info before running it. nVarious remeshing parameters can be found at nRegards,nKeyurnnIf this helps, please mark this post as 'Is Solution' to help others.nnHow to access ANSYS help linksnn
