kirstenbraun
Below I have attached the image of what happens when I select the imprint tool. As you can see only certain edges and faces are highlighted. I would need all contacts between the various sufaces (whos topology has been shared) to imprinted onto one another, so that the mesh for the 1/17 model is exactly the same when it is rotated using the patern tool. The tolerance is set to the default of 0.1mm.nn
