Karthik R
Administrator
You are solving a CD nozzle. Using a pressure inlet Boundary condition is more physical. It is something that you can measure experimentally.nBut now that I see your geometry, you should be able to use the mass flow rate condition as well. nI hope this helps.nThanks.nKarthikn
