DrAmine
1/Check if your UDF's require some parallelization or you are using auxiliary UDF's requiring parallelizationn2/Check if the partition boundary is lying in some sensible region and choose then other algorithmnnIf 1/ and 2/ are fine probably both cases are not really converging.nAlways include the release working with in your posts.nn
