MadScientist
For the other opening it's a pressure inlet at 0 Pa. I will put in your recommended settings and run the simulation. How do I account for compressible effects? Should I use the density based solver? Also, should I first run the simulation with first order settings and then switch to your settings for momentum and time, or can I start straight away with your settings?nLastly, by higher order discretization for momentum, do you mean second order?n
