DrAmine
You should not modify the connection between the solid and Fluid. Keep it coupled.nI recommend that you read the mesh from scratch and the interface connections will be done automatically. Check them to see if they are fine. I usually use for non conformal connection between solid and fluid the projection method. That is the one behind Coupled Wall Option. Once setup:do not do anything:setup your case and once you initialize assign the solid region the high temperature value.nn
