It should read the profile in regardless of the case file, it's when you try and add it to a boundary that problems can occur (usually when the profile is for a different location). Check you can initialise & run the poly mesh without the profile then see if it'll read in again. Then double check that file will read onto another model in case you've got a corrupt or damaged file. n
