Karthik R
Administrator
In the Pressure Farfield BC, you specify the Mach number directly. When you use the pressure inlet BC, Fluent is attempting to compute the velocity from the pressure value. I'd suggest that if you know what your reference values are, please manually input these values. Reference values are used for post-processing parameters.nI hope this helps.nThanks.nKarthikn
