The solver makes as many iterations as it needs to compute equilibrium. The more nodes and elements you have, and the more contact you have, the longer it takes.nSome things you can do to make the solution take less time is to:n1) limit contact to smaller facesn2) replace the thin-wall solids with midsurfaces so that you can replace solid elements with shell elements.nn
