September 10, 2020 at 7:03 pm
I had a model with bolt pretension applied in Step 1, which took a long time to converge, and was a common first step for all analyses. Then I wanted to apply many different forces in Step 2, which took very little time to solve. If you have that situation, then there is a simple method to save time.nThe important Analysis Setting is under Restart Controls, where you want to set things as shown in the image below. n
Now you solve that model. The result will be a solved model for step 1, but ready to restart. In Workbench, you duplicate the solved Static Structural model System A. In the copy (System
you read in the results file from System A. Suppress the Command object, edit one Force and Activate the load for Step 2. Now Restart the solution. It will start at the end of load step 1 and quickly do load step 2. You can repeat this process for each force in the model, making copies of System A to make System B, System C, etc.nI wrote those instructions many years ago. There may be a simpler way now. You can see if anyone else has a better workflow.n
