tsiriaks
Hi Aamir,nYes, that seems good in your ansyslmd.ini nFor 'User License Preferences' , you can just search this term in your Windows Search, it should show a shortcut to launch a tool.nStatic Structural is just for a test to see if you have the same issue with solver license. It's not intended to be a replacement of your crash analysis.nAny chance you can update to a later version like 2020 R1 or R2 ? Because there is another licensing trick that we can try if you are using these recent versions.nThanks,nWinn
