Insert a Command with the NCNV command.nNCNV, KSTOP, DLIM, ITLIM, ETLIM, CPLIMnSets the key to terminate an analysis.nKSTOPnProgram behavior upon nonconvergence. Default 1 is to terminate if solution fails to converge.nDLIMnTerminates program execution if the largest nodal DOF solution value (displacement, temperature, etc.) exceeds this limit. nITLIMnTerminates program execution if the cumulative iteration number exceeds this limit (defaults to infinity).nETLIMnTerminates program execution if the elapsed time (seconds) exceeds this limit (defaults to infinity).nCPLIMnTerminates program execution if the CPU time (seconds) exceeds this limit (defaults to infinity).n
