nWhat is the problem? Is it that the beam profiles are at right angles to each other where the beams connect? Did you want the profiles trimmed to 45 degrees at the connection point, the way two I-beams would be cut before welding together? ANSYS won't show that.nThe simple solution is to turn off the beam profile. The two lines are the geometry.nThe profiles are just a visualization. Mathematically, the two lines are connected and their bending properties are defined by the beam profile.n
