Relevant comment from on using linear elements in the mesh for thermal models here.nhttps://forum.ansys.com/discussion/18457/solid70-elements-are-giving-higher-temperature-than-solid90-in-moving-heat-source-modelling#latestn
New Post - Reply To: Radiation heat transfer solution in ANSYS mechanical Steady State Thermal
