Okay, that is a good reason to have them. In that case, set the defeature tolerance to a size of 0.4 mm so the lip does not disappear. Then in Bonded Contact, you can just pick the face of the weld.nAnother way to model welds is to let the weld bead be a separate body and use Shared Topology or Bonded Contact to hold the parts together.n
