MichArcher
                      S O L U T I O N  O P T I O N Sn n  PROBLEM DIMENSIONALITY. . . . . . . . . . . . .3-D                 n  DEGREES OF FREEDOM. . . . . . UX  UY  UZ  ROTX ROTY ROTZ TEMPn  ANALYSIS TYPE . . . . . . . . . . . . . . . . .TRANSIENT           n     SOLUTION METHOD. . . . . . . . . . . . . . .FULL                n  OFFSET TEMPERATURE FROM ABSOLUTE ZERO . . . . . 273.15   n  NONLINEAR GEOMETRIC EFFECTS . . . . . . . . . .ONn  EQUATION SOLVER OPTION. . . . . . . . . . . . .SPARSE            n  NEWTON-RAPHSON OPTION . . . . . . . . . . . . .PROGRAM CHOSEN  n  GLOBALLY ASSEMBLED MATRIX . . . . . . . . . . .UNSYMMETRICn n *** WARNING ***                        CP =      3.922  TIME= 16:51:24n Material number 4 (used by element 36591) should normally have at least n one MP or one TB type command associated with it. Output of energy by n material may not be available.                                         n n *** WARNING ***                        CP =      3.922  TIME= 16:51:24n No constraints have been defined using the D command.                  n n *** NOTE ***                           CP =      4.297  TIME= 16:51:24n The step data was checked and warning messages were found.             n Please review output or errors file (                                 n C:\Downloads\Simulation\_ProjectScratch\ScrE0EE\file0.err ) for these  n warning messages.                                                      n n *** NOTE ***                           CP =      4.297  TIME= 16:51:24n This nonlinear analysis defaults to using the full Newton-Raphson      n solution procedure. This can be modified using the NROPT command.     n n *** NOTE ***                           CP =      4.312  TIME= 16:51:24n Internal nodes from 45834 to 45837 are created.                        n 1 internal nodes are used for handling degrees of freedom on pilot     n nodes of rigid target surfaces.                                        n 3 internal nodes are used for non-contact elements with mixed          n formulation.                                                           n n *** NOTE ***                           CP =      4.328  TIME= 16:51:24n Internal nodes from 45834 to 45837 are created.                        n 1 internal nodes are used for handling degrees of freedom on pilot     n nodes of rigid target surfaces.                                        n 3 internal nodes are used for non-contact elements with mixed          n formulation.                                                           n n *** WARNING ***                        CP =      4.359  TIME= 16:51:24n Contact element 36594 is missing DOF TEMP (and possibly others) of     n underlying base element 1745. Similar mismatches may exist elsewhere, n but checking for this is discontinued.                                 n n *** NOTE ***                           CP =      4.375  TIME= 16:51:24n Rigid-constraint surface identified by real constant set 2 and contact n element type 2 has been set up. The degrees of freedom of the rigid   n surface are driven by the pilot node 45833 which connects to other     n element 36591. Internal MPC will be built.                            n The used degrees of freedom set is UX  UY  UZ  ROTX ROTY ROTZn ****************************************n n n n n *** NOTE ***                           CP =      4.391  TIME= 16:51:24n Internal nodes from 45834 to 45837 are created.                        n 1 internal nodes are used for handling degrees of freedom on pilot     n nodes of rigid target surfaces.                                        n 3 internal nodes are used for non-contact elements with mixed          n formulation.                                                           n n n n
