ahm.eltaweel
Unfortunately, the original selection can't be created using a worksheet due to the complexity of the geometry surface.nI have to select these facets one by one in groups. And once the selection is done, I can't edit its coordinates.nThen I have to figure out a way to reflect this selection to the other side of the model.nIt seems the only way is to select these facets individually on each side considering obtaining an identical end result on both sides.n
