Chris Quan
In WB Explicit Dynamics system, first you need to activate the beta feature to expose SPH method under WB Options. Then you need to change the Reference Frame of the body to Particle under Geometry. Finally, you need to use Discrete Element method under Mesh to generate SPH particles. ANSYS 2020R should be used. n
