Surya Deb
Hello, nFor force and Torque calculations, please make sure that your mesh is well resolved around the body of interest. You should ideally have 5 or more boundary layers.nAlso please check the Wall Y+ values to ensure that they are not high. nAre you using SST k-omega for Turbulence? Then having a wall y+ around 1 should enable you to predict the forces and torques on the body in an accurate way.nRegards,nSuryann
