September 15, 2020 at 6:03 pm
/EFACET controls the fineness of the subgrid that is used for element plots. The element is subdivided into smaller portions called facets. Facets are piecewise linear surface approximations of the actual element face. In their most general form, facets are warped planes in 3-D space. A greater number of facets will result in a smoother representation of the element surface for element plots. /EFACET may affect results averaging. nFor midside node elements, use NUM = 2; if NUM = 1, no midside node information is output.n
