September 16, 2020 at 1:20 pm
Hi,nPlease share the profile data of your simulation model by using the snapshots of the whole profile to help us serve you better (you can access this by right mouse click on Results->Solution data->Profile). Also you can use first order basis (you can check this by double mouse clicking on analysis setup->options) function for faster simulations. The simulation time also depends on the type of solver being used. For more data regarding the solver types, kindly go through the Help document.nAll the very best.nBest Regards,nn
